randomguy12
Ok, I recently got an Audigy 2 ZS card, along w/ the Logitech z-5500 serries speaker set, and for some reason the card(im asuming) keeps freezing my PC. The only game I really play is World of Warcraft, so i'm unable to determin if it does it with other games as well. But anyway, my entire computer will just lock up when im playing, and I will have to turn it off, then back on again. It doesn't just lock up instantly though, it will make some crackling, then freeze, and make high pitch sounds. It will also blue screen, and say its something to do with either the hardware, or the software. Also, the WinXp error report sender, says that it's something to do with the device drivers, but thats it. It doesn't happen at random times, it only seems to happen as the day progresses, usually happening later-late at night. So i'm not sure if it's a heat problem or what. Also usiing a PCI-e GForce 6600, so I moved the card down to the last PCI slot in order to free up some more air space. That didn't seem to help either. I sent Creative a tech support e-mail, and they send me to a website to DL some new drivers....that didn't work. Any ideas? Heat, or something else? The temp isnt really that high...the intermitten fan kicks on every once and a while, but thats about it. So im not sure what it is.
