Audigy 2 ZS problem?
MrToilet
I've been having a really, really annoying problem with my Audigy 2 ZS. A few minutes into playing any DirectX game (Max Payne 2, UT 2004, Half Life 2, etc), the audio suddenly becomes garbled, I get a static type sound, the audio loops, and the game freezes. The only way to get out of the game is to restart.
I have the latest drivers for Audigy 2, and the 77.72 Forceware drivers for the 6800, and the latest nForce 3 chipset drivers.
Setup:
Athlon 64 Venice 3000+ @ 2.6 gHz
Corsair XMS 1 GB
BFG 6800 OC 16/6
Audigy 2 ZS
DFI LAN PARTY NF3 Ultra
I'm wondering if my overclocking has anything to do with this? Right now I'm running the CPU @ 290x9, RAM is on the 2:3 divider @ 195. Would the extra speed be stressing out the PCI slots?
By the way, the Audigy 2 ZS is on the lowest PCI slot. There are no IRQ conflicts or anything like that, so I'm really confused.
Thanks for the help!
If the pci clock is not set to run async, it could be a problem.
Has this problem always happened? What if the PC isn't overlocked?
If changing PCI slot doesn't work, I recommend the pci latency tool but only if the previous measures were tried first because I don't think the tool would work anyway.
I know this is a dumb question, but where is the PCI clock? I've looked through the BIOS and haven't really found anything relating to that. Where would I start looking?
And I've had it happen when the PC isn't overlocked (200 FSB instead of 290). It just takes longer to freeze up, but I think that may be subjective. The problem is that it still happens!
What "speed" are the PCI slots supposed to run at, anyway? How does it relate to AGP/FSB speed on Nforce 3 boards?
