Audigy 2 Front Panel Audio Connectors
Robotoer
39
I bought a Sound Blaster Audigy 2 zs Plaitnum recently. When i put it in my computer after having bought a new case, I had no idea how to hook up the front panel audio connectors. I had used a dell before doing a rather large scale upgrade after my dell motherboard got fried by a new powersupply. In my dell, the Front panel audio had this long connector that fit right into the sound card. The audigy 2 has the same long connector spot, but my new case has all seperate pins. I can hook them up to the motherboard front panel audio, but not to the card because of two reasons:
1. There are no instructions for hooking up front panel audio with the creative card so i have no idea what to plug in to what.
2. when i try to plug in the front panel audio connectors(they're individual pin things) the size of the black plastic sheath makes them make it so that when two are placed together they make it so no others can be plugged in around them because of the size of the black plastic sheath.
Does anyone know how to make this work?
Thanks
imported_Nacelle
933
When I first saw your post, I thought you where asking what do people use the connectors on the front of the Platinum for. I was going to say I plug my guitar into it. But after reading the entire post, I'd have to say I dunno. There's got to be a pin assignment somewhere.
Navid
5,053
I don't get it! If you have the Platinum, you should have got a front panel with it that can fit in a drive bay. Use it. Why do you want to use your case connectors?
If you wanted to use the case connectors, why did you pay extra for the Platinum?!
http://audigy2zshowto.blogspot.com/
This tells you a way to connect the pins with some level of success!
Reapsy00
Creative prolly did it on purpose to encourge ppl to buy more expensive cards with a 5.25" front panel jobbie
