Thetech,
Considerations + bit&bobs for fun and for free
Google, annealing brass. The pins are made of brass and once heated to discoloring the tin flash plating and cooled rapidly, all clamping force is gone. So cleaning and reusing is out of the question for this old mechanic, no matter how well they are cleaned or rebent.
Your Seasonic most probably uses genuine Molex pins. Cheapy extensions are made on a heart stopping production line by 12yo childern using knock-off molex-type pins & shells. I hear it now, "old know it all telling me silly stuff". Well, I've crimped several hundred Molex pins over the last six months and the pins from Action-Ellectronics.com are the real deal. The pins that come from vendors selling a row of several pins with a shell are thinnner and have less clamping force. Genuine Molex are thicker by several thousanths of an inch. Does it make a difference...Yes!
For my own rigs no extensions or adapters will ever be put into play. An extension for a fan, maybe. Anything else? NO! Solution? Cut, splice, solder and heat shrink.
Pins & shells=
http://www.action-electronics.com/
VG ratchet crimping tool, that will be passed down to your Grandchildren=
http://www.jab-tech.com/ >Tools@$20.
For the Full-Zoot service life of all connections, plus real world increased life from all batteries, use a trace of ProGold. To be seen here=
http://www.caig.com/ No connection should be made up dry because air oxidizes metal, thats why the critical contacts are flashed with gold, like CPU pins, RAM and all other cards.
Zepper gave me a real heads-up on the crimper & ProGold. I gave him a real heads-up about quantity buys of pins/shells from Action-Electronics.
...Galvanized
