ATX PS in AT case?
It's gonna require lots of drilling and cutting since ATX boards are configured differently. In fact, it's even at a different angle. You could but why? Cases are pretty cheap and it's not worth the headache.
Windogg
Changing out the power supply is easy, all of the holes will be in the right place. You need to change the switch also, depending on your case this may or may not be easy. Once completed, you will be restriced to hybrid mobos,they must be AT format with ATX PS connector. Many Socket 7 & Super 7 Mobos fit in this catagory. You will run into a lot of troubles if you try to put in a ATX mobo, that is when some major case mods will be necessary. I recently did this to my trusty old black tower into which I first installed a 286 in about '92. It is now a K6-2 450 in a FIC 503+.
Windogg, are you referring to a desktop AT case with a power supply that comes in a large box, maybe with a toggle switch on the side? Because the tower AT cases I've seen that use the small supply will accept an ATX supply with no changes at all, and all the screw holes line up perfectly.
