ATX Power Switch hack question
Woodie
2,747
Need just a little help/confirmation.
I'm modding an old AT case to a new ATX board (MSI nforce2)...
I've got a momentary rocker switch almost mounted, I just want to confirm the wiring.
Can I just wire the 2 switch connections to the two pins labeled "Power" in the front panel connector block?
beatle
5,661
AFAIK this is how all power switches work on an ATX case, so you should be good to go.
