ATX Full tower case question
medusaccino
305
i am gonna run 1 Gig AMd with KT7A-Raid on it. i need a full tower case for it. i am gonna jam it with high storage harddrives. whats a good case for this combo?
Mavrick007
3,198
Depends on if you want lightweight cases or not too, like the Aluminum cases.
Antec and Enlight are good cases as well as In Win and Aopen cases too. Aluminum cases are expensive and I don't think they offer much benefit except they are "lighter" but I don't think you will be carrying your full-tower around town very often. Go for one of the cases that were listed above and you should have a good machine.
jcmkk
1,159
It would really help if you told us a price range. Do you have any other requirements?
medusaccino
305
well i am thinkin about using all my IDE drives plus my controller drives. so thats (CD-RW + DVD) + 2 IDE + 4 on the COntroller + floppy. so thats like 9. i dont care about the price just dont go over $130 or something.
jcmkk
1,159
Even though I'm not a big fan of them, I think that the Antec full tower cases would fit your situation best.
ojai00
3,291
Antec/Chieftec (similar cases, different companies) will do you just fine. The Inwin towers mentioned above are also spacious enough to include all your drives. With your budget, it seems like you can get a good enough case to suit your needs.
Check this link for a good deal on Antec-like cases.
Hope this helps.
networkman
10,436
Personally, I like SuperMicro full-tower cases, specifically the SC-750A
I own two of them(used to have 3), both are running with dual-AMD combos and lots of HD space. :)
