ATX case with 250watt ps $19.95
Bagger
1,445
I just bought this exact case at a local computer store. I paid $33, the exact price it would cost to have this system shipped. Except I got mine same day! :)
Bigdude
Everytime, I order I get a different case, some ar better than others, I wish they still had the desktop atx for $12.95.
LedFusion
148
This case sucks.
Don't waste your money on the frustration it will cause you.
Also, when it fails, they will be sorely lacking in terms of rectifying the situation.
Led
Vpham97
477
I posted the deals about this case back in Nov or December.
I like how it has alot of ventilation holes on the side.
It look a lot better than if I put it there myself w/ a Dremmel.
railer
1,552
69
This case is OK; I've got one. But the PS is right in the way of the MB, so if you need to get at the CPU with any frequency it becomse a pain in the a#$. I will be spending a few more beans on my next case...
tji
113
I have a couple cases like this one.. It does the job for a basic setup.
But, for more extreme needs, a little more is needed.
I have a system that runs hot, (dual processors, 3 SCSI drives) so I put it in a Coolermaster ATCS 200 case. It's an excellent case, all aluminum, well vented, etc. But, at almost $300, it's a bit pricey.
Then, there is the Lian Li aluminum case. It's looks similar to the coolermaster, but gives the impression of a step or two down in quality. It can be had for $230 or so.
Anyone know of any better deals on Aluminum cases?
Bigdude
I have a Inwin full tower, that is old as the hills. It was my first ATX case, had a Abit SM5 with a P166. Still have the case, and original 235watt ps, it's running a MSI K7Tpro2A Duron at 850. I have a Gigastar midtower with a 250watt ps, really nice case, very heavy steel, it's running a Asus K7M with a 650 Athlon, most stable system I've ever had. I bought a couple mid tower cases at that auction place, with the transparent grey front, and a 300watt ps, well the ps lasted one day.
cmv
3,490
I've ordered these a couple times - at one point in time they sold them via egghead.com's auction site and a free shipping coupon was floating around, wish I'd ordered a ton back then. I also received slightly different cases each time. So far I'm happy. Of the 3 only 1 seems to be getting a bit funky (the power supply makes odd noises, gone now though). If you want a cheap case and don't fiddle with the CPUs a lot these are good. Personally I'm getting a tiny bit nervous about the quality of the power supplies in them so I'm going to upgrade soon (actually building a case that will hold 2-3 motherboards plus power supplies and drives :)).
