I need to get an active NB cooler since pretty much im running the stock one. Would appreciate some feedback on what you are using and the results compared to stock.
Looks like the BR123 is what most seller have as far as brackets are concern. Might go that route and add a quiet Panaflo 80mm L1A to it directly over the NB .. thanks guys for the 411
