- Jan 4, 2001
- 41,596
- 19
- 81
I recently bought this modem used on the forums. The adapter that was included is marked "9VAC" while the modem calls for 12VDC. The seller says he used this adapter with no problems, but I'm not about to plug AC power into something that needs DC.
Now the problem: the modem isn't marked as to which is positive and which is negative. So I need someone to have a look at their modem's power adapter and tell me the polarity.
Thanks.
Update: Got it. Netsysadmin, after checking the pics of your modem, I figured I'd test out something with that polarity. I found a 9VDC adapter, and it powered up the modem. I've now got a 12VDC 1.0A adapter on the way. So, thank you.
FYI
Motorola SB5120's power stats:
- 12 VDC, 0.75A input
- 5.5mm outer, 2.5mm inner diameters
- center positive
Too bad Motorola's documentation doesn't include that information anywhere.
Thanks.
FYI
- center positive
