- Jan 7, 2012
- 107
- 0
- 0
I have a water damaged SGSII, the entire phone was not submerged, mainly just near the battery area.
Phone Symptoms:
- Everything works fine except the phone's screen will turn on randomly on its own, then stay on. If you tap power to turn the screen back off, it will sometimes turn back on after 30 seconds, sometimes 10 minutes.
-The phone goes into battery drain HyperDrive once you pull it out of your pocket and notice that it has frozen in the screen on position. It goes from full battery to nearly dead in around 45 minutes in this state, otherwise BL is good.
What I did:
Took phone completely apart. Scrubbed using toothbrush and 91% isopropyl alcohol and put it back together. Phone acted slightly "improved" but still not fixed.
Took phone apart again, scrubbed harder this time with a washcloth as well.
What next? Considering this is probably going to be my last resort I suppose, I was thinking of going with a high grit sandpaper and try to walk the line between removing corrosion and removing vital components to the phone - just scrub the hell out of it. Thoughts?
Phone Symptoms:
What I did:
