Attempted to reset monitor settings, but now my Sony CRT has problems.
aggressor
2,079
Well, I somehow managed to break my working Sony G400 somehow. I had disconnected it to try out an LCD (Viewsonic VX924 by the way) and when I hooked it back up, the weird idea of resetting my CRT back to defaults entered my head.
I disconnected the d-sub cable from my PC, and proceeded to hold the monitor's menu button down. Some grey screen popped up. I then held the left button down for 2 seconds and another greyish screen came up. After about 5 seconds, the monitor went back into "No input signal" mode, but the picture was extremely bright and it had horizonital blue "lines" on them. I've tried everything, and I can't get them to disappear. Not only that, but if I open something pure white (like a blank webpage), the image expands and then shrinks\dulls in color.
What the hell did I end up doing? Is there any way to fix this? Multiple google searches with different key words have come up with nothing. I really don't like LCDs, and there don't seem to be any good 19 inch CRTs left, or at least ones with the same, or better, quality as my G400.
Bozo Galora
7,271
a. you put the 15 pin dsub in the secondary slot, not primary
b. you bumped switch to secondary position
c. FWIW: reset to defaults is a push button on back of monitor
d. you set menu to locked
e. you did a color restore, involving a 30 minute time period that you did not wait, and did not have monitor connected
(page 14 of manual)
http://www.sony-cp.com/manuals/archive/g400.pdf
aggressor
2,079
The reset button is on the front, not the back. And you can't do a color restore when the monitor hasn't been on (really on, with an image on the screen) for 30 minutes, as far as I'm aware. Maybe holding the button for 2 seconds, or holding the left button for 2 secs does an image restore? I'm not sure.
The rest (abd) aren't true
