Is it supposed to be a struggle to clip a heatsink to a motherboard? I got a Taisol heatsink (CEKxxxx), and I pushed and prodded and nearly broke a couple of capacitors trying to get the other end of the clip to snap down. I ended up using a screwdriver and pressing down against the upper hole (there's two holes on each end of the metal clips). All the while, I'm thinking, there's gotta be an easier way to do this. I plan on removing it and applying thermal grease, but I really don't want to go through the effort again, and I'm afraid while I am putting the heatsink back on I'll end up smearing the thermal grease all over.
Suggestions?
Suggestions?
