Attach old 486 cpu fan to voodoo3 2000 heatsink
Miraluka
161
OK, so my voodoo card has a heatsink on it as default. Its exactly the same dimensions as a fan off of an old 33mhz 486 cpu i have. any ideas on how to attach to two? preferably without drilling holes into my card or the heatsink? I know i can just push some screws through to hold them together, but i dont want to do too much damage to the card or heatsink.
jsbush
3,871
Use elastics! I dont thing the v3 2000 has wholes in the heat sink so those little tie things that come with garbage bags are no good.
Miraluka
161
The problem with that is the fact that the heatsink is above the area where you insert the card into the agp slot.
And yes, you are right that the heatsink does not have holes for screws to go through.
Dan
Miraluka:
I posted this a few days ago in a similar thread.
<< aznmist: I don't know if your video card came with a fan for the heatsink or not. My CardExpert GeForce 2 MX doesn't come with a fan. I took a new 486 CPU fan and attached it to the heatsink. It fits perfectly and is certainly better than nothing. >>
<< Rojas: The 486 CPU fan and it's heatsink were held together by a plastic framework with four plastic &quot;posts&quot; that went into the fan's screw holes. I took it all apart and snipped the four &quot;posts&quot; off the framework. Then I put Super Glue on the posts and slipped each of them into the fan's screw holes. (I made sure each one stuck out of the fan as much as possible.) >>
Poof
4,305
You guys are so fancy... ;)
The clips of the 486 fan that I have jam nicely in between the HS fins on the V3 card. It's been running that way for 5 months now... Hasn't fallen off yet.... :)
Miraluka
161
DOUBLE SIDED FOAM TAPE BABY! THATS THE WAY TO GO FOR ME!
hehe, thats what i'm gonna be using, no pins or screws or elastics for me.
wj
I used superglue the gel type, to put a 486 fan on a voodoo card. Been on for over a year now, check it on sunday still holding on good.
wj :cool: :cool:
GiZzO
1,789
Yep the heatsink belongs for Xeon processor, HS is always air cold, got the stock HS taped on the backside which does help.
What funny i don't think that pic shows it but that HS is so heavy the end of the card is all tweaked and bent down. :p
