Originally posted by: MacVista
I have the made by ATI Radeon 9800Pro 128mb and it has worked wonderfully for years. I don't think it has any overheating problems...
Originally posted by: duragezic
Unless you have EXTREMELY poor airflow and cooling in your case, of course its going to be fine at stock speeds. They have to design those things so that retards with horrible case temps can put them in and have them work fine. So yes they may get "hot", as in hot to touch, but not that it can't work fine at those temps. I don't know what my 9800Pro temps were since it didn't seem to have a temp monitor, but even overclocking it to 395/355 (never tried any higher) it still worked normally.
Originally posted by: buddhika
thanks
what is the highest overclock did u have done (with stock cooling)
1. is 9800XT is much better than 9800pro 256mb? (if i am not going to overclock)
2. what are the compatible aftermarket cooling (air-fans) systems for ASUS 9800pro ??
thanks
Same here... but I use DVI.
