BobDaMenkey
So I went to replace the hard drive on my PS3 and there are a few TINY phillips head screws to hold it in place. 4 on the cage and one to hold the cage in place. I went at them with an eye glass screw driver but it was a bit too small, and then I dug around in the garage for some slightly larger phillips head screwdrivers that fit just right.
However, I can't seem to get enough torque on the screw to break it loose. What should I do? Try using a pair of pliers to get more torque applied to the screw driver? Get a screw driver with a bigger handle so I can use more than my thumb and a few fingers to put torque on it?
