- Apr 19, 2001
- 25,284
- 1,998
- 126
Toilet just started acting up. Here are the symptoms:
The tank fills and retains water normally.
When flushing the bowl won't really flush. It just kinds of fills to the brim as new water comes in.
After it fills the water slowly leaks out of the bowl until it's gone entirely. While it's happening you can hear the sound of the water escaping.
Once the water disappears completely there's a gurgle and then a couple of inches of water bubbles back into the bowl. Bowl retains maybe 1/20th of it's normal volume.
Back to step one. Flushing again fills the bowl completely, water drains out slowly until gone and then a little comes back into the bowl from where it normally leaves
No evidence of leaking anywhere around the toilet or on the ceiling of the room underneath the toilet.
