- Feb 23, 2005
- 11,940
- 542
- 126
I've put together a small home recording studio. It isn't much, but I think it has a lot of potential. FWIW, Ubuntu-Studio has some killer software if you put the time into figuring out how to run it.
For the guitar, I purchased a POD XT to record direct -- it seemed like the most simple solution. The signal is there, but I'm getting really bad line hum, to the point that it's significantly audible during play, not just while the strings are still, so it simply won't do for recording as it is.
The signal path is guitar -> POD -> Behringer mixer -> MAudio 24/96.
My main axe is one I've had for years, and it's pretty gig-weary. I've resoldered a bunch of the wires internally after they've come loose over the years, and had the tone pots taken out of the loop entirely (don't ask me why, it was years ago), so it's basically just the volume knob and the pick-up selector. I have another axe that I won in a battle of the bands some years ago, but its all single coil so I don't think it's gonna help me with my hum problems. It has a broken nut at the low E so I haven't bothered to get it out to try it anyway.
I'm trying to decide if I should have the internals of my main axe gutted and replaced, or simply to purchase a new (used) guitar off CL.The bridge pickup is a Seymore Duncan Screamin' Demon that I'd like to keep but the others are kinda meh, but just adding up costs in my head, it might not cost much more just to get a new axe. It is something I've wanted to do for a while anyway, so this might just be the time to do it.
I'm also curious about how significantly the wiring behind my desk might be adding noise to my signal lines, and I have more experimenting to do with that. I've heard also that computer monitors can inflict noisy wrath on guitar pickups in close proximity, so I need to play with that as well.
Cliffs:
Lots of hum in guitar signal to home recording PC.
Might be the old n' busted guitar electronics
Might be the cabling (power & signal)
Might be the monitor (or all of the above)
Thinking of getting new axe instead of fixing old one.
Open to other hum-fighting suggestions.
Help me ATOT! I am lost in a sea of ignorance and indecision!
Cliffs:
