OK guys, back to ATOT with more questions - this time, electrical. I got two new dimmers that require a Load, Ground, Hot, and Neutral connection. My old dimmers didn't need a neutral wire, they only had load and gound (I guess). I need to figure out where to get a neutral connection for these switches. I'm pretty sure there's one in the box, but not positive. Bound together are four white wires (there are 2 switches in this box). I am assuming that these are the neutral connections, and I guess the installer tied the two from the lights to the two from the box. Since both these new dimmers require neutral, should I just stick both neutrals in with the bunch, or do I need to somehow seperate them and find out where they go? Anything else that needs to be done?
Thanks for the help...
Dan
PIC
Dan
PIC
