Originally posted by: dpopiz
Originally posted by: Nocturnal
Originally posted by: axelfox
try mixing on some regular home stereo one
mhm...
anyway what's the difference besides "ooo you just know it's better because it says 1200"?
Couple of things:
1. Start/stop times. You can cue up a record to the exact spot you want to begin playing at and hit the stop button or hold it with your hand. As soon as you let go or hit the play button you're instantly up to speed, you don't have to wait the second or two while the table spins up to speed.
2. Pitch control. With regular record players you have usually only 2 speeds: 30 and 45. With real tables you have the two basic speeds and then you have a slider to adjust the exact pitch (usually + or - 12% of the baseline speed). If you are doing real DJ'ing and beatmatching you cannot live without this feature.
3. Ruggedness. Turntables are meant to be beaten around. Grab the table and stop it, spin it more quickly with your hand to get up to a certain point, scratching, or just the rapid push forward/reverse until you get it right on beat with your other record. Do this on a regular record player and you'll burn it out quicker than you can say "I'm an idiot."
4. Design. Record players put the tonearm right where your hand would be if you were scratching or cueing up a record. You'll knock the arm off and probably scratch your record. Tables are designed for the DJ and place the parts that have to be there out of the way so that in the end it's just you and the record without a lot of other crap in the way.
You don't need 1200's when you are starting, but it is highly recomended because that's what EVERYONE uses. If you ever play any club 99% of the time that's what they have. The reason is because they are perfect. You can start with a good set of Gemini's that are direct drive, but sooner or later you will be buying a set of 1200's. If you know you want to DJ, spend the few extra bucks now and get what you need now. The added benefit is that you don't have to get used to the "feel" of a different type of table down the road if you've always trained on techniq's.
EDIT: 5. NEEDLES! The shape, angle, and texture of your needle means a lot if you're trying to save your records and DJing. Regular record player needles are meant for one direction with not a lot of excess movement. You'll break them or mess up your records very quickly on a regular record player. Turntable needles are designed with the abuse of DJing in mind from the beginning (consequently the ones I use are hella expensive, but they are worth it
