Originally posted by: geforcetony
Originally posted by: xtknight
good this is how it should have been done in the first place. will the memory between the two cards be combined or not? if it's implemented on the hardware level, any software will work with it. this is something I may actually consider, considering it's better implemented than software with overhead. I hope there's an advanced load balancing algorithm. depending on how low-level AMR is, you might not even need that. i love solutions that are transparent to software. easy to implement, and theoretically twice as fast (versus (twice as fast-overhead)).
The memory will have a 99.9998% chance of
NOT being shared between the 2 cards, and will probably work just as NVIDIA's SLI does in this respect.
As Rollo said, just because it will "support" all apps, doesn't mean that it will be faster on all apps. SLI can be forced on just about everything, but that doesn't mean that it will gain a worthwhile performance boost (or any performance boost at all).
Personally, about the DVI adapter thing, since ATI said that their "AMR" will work on all PCI-E cards (at least, all PCI-E ATI cards
😉 ), and some of those are DVI\VGA, what happens if you have only 1 DVI port on each card? I agree that there's probably a passthrough thingy, but if there's not, what are you to do? Even if there is, do you really want to have your monitor cable sticking out a good 6-8 inches from the back of your computer? I don't know of many people that would. Besides, it would just be really annoying. Seeing this whole thing with the dongle\passthrough thingy, makes me like NVIDIA's bridge chip more. If ATI had just gone with plugging 2 PCI-E cards into a compatible mobo, and no adapters, bridges, or dongles needed, then maybe I would think its better, but the way it stands with the adaptermaboby thing, that just plain out sucks.
