aticfx64.dll problem
lanmonkey
all of a sudden photoshop stopped loading with a aticfx64.dll error. so did adobe premier and Avid Media Composer gave me this error
________ Exception Report ________________________
Exception Code: C0000005 ACCESS_VIOLATION
Fault Module: 01:0008F91E C:\Windows\system32\aticfx64.dll
Fault Address: 000007FEEEB3091E AmdQueryPowerXpressDeviceInfo+2822E
I have removed my ati drovers and installed the latest beta with no luck. I have a HD6900 series card
game and everything work fine its just some applications that I really need to use just stopped working all of a sudden.
all the support pages for the apps say "reinstall your drivers", well I done that several times
any ideas?
Yup...run CC Cleaner's Registry Cleaner then restart.
That will remove any uninstalled dll traces.
You could also try system restore to a date before your recent crash.
I presume those programs were functioning correctly previous to your current problem?
