While recording TV in MMC 8.8 the sound loops but while playing the recorded file there is no echo. How do I stop the echo from occuring while I'm recording?
I had a similar problem with my AIW but only when using the pause live TV. I deleted the files in the ATI MMC (using in C: ) directory and all was well.
