I have a new ATI TV tuner card pro VE. This is the card that is the TV tuner only. I have a G-Force2 running on windows 2000 server. For some reason I can not use the feature of blended window. This allows me to run tv and as I use other apps, I can see the tv through the window on top. It is not working. I have setup according to manual. That did not work so I down loaded the new detinator drivers from nvidia that supports transparency. It works fine with all my apps, but when I open the tv app the trancparency tab is greyed out so I can not select it.
Any suggestions that anyone can give me to get this running?
Advanced thank you,
Advanced thank you,
