ATI Silencer 4 $20.95 + shipping
Krome20
46
Does anyone know of a good cooler like this for Nvidia? I have a GF4 TI4600 and my fan started making loud obnoxious noises and now I'm using and old card.
Thanks
TwiceOver
13,544
44
Originally posted by: sheltem
I had one of these for my Radeon 9700 pro. They're really quiet and it is easy to install. I'm waiting for the Geforce 6600GT version. The XFX fan is pretty loud.
So does This version work with the 9700 Pro or are you talking about a different one?
EDIT: Nevermind, ordered a Rev.1 from SVC with some fans. Even though the silencer was cheaper at coolerguys shipping the fans and shipping were cheaper at SVC bringing the cost down to a dollar less than the Coolerguys wanted.
Krome20
46
I found the same one as in this thread for $22.49 + shipping for nvidia cards. The NV Silencer 1 will work with the GF4's and other models will work with newer cards. One of the reviews mentioned it not fitting with his PNY Geforce4 Ti4200 8x because it only has two mounting holes but the cooler has 4. I have a PNY GF4 Ti4600 4X and the fan that is on there now is attached to the card with two holes in opposite corners but there are an addiotional four empty holes on the bottom in a square pattern. Are these the mounting holes to be used or is it the two catty-corner holes?
Slickone
6,120
I'm curious about an answer to Krome20's question. I think my Visiontek 4600 has 4 holes, w/ the stock HSF using 2.
xfosx
241
Would anyone happen to know which version of the silencers I would need for the Powercolor Radeon 9800SE 128M 256BIT card? I softmodded mine to the pro & I need something a bit more efficent then the stock cooler now.
