Hi all.
I'm trying to run BF3 in 1920x1080 on my 30" Dell (2560x1600) I would like the black bars to appears.
I'm using the displayport cable and I've done a fair bit of googling.
This thread doesn't help.
viewtopic.php?f=3&t=68072
The option is under "Digital Flat-Panel" section of the drivers and it's called "Image Scaling" - it has options for "Enable GPU scaling" "maintain aspect ratio" "scale image to full panel size" and finally "use centered timings" - these are greyed out when I'm at 2560x1600 (windows)
Even if I drop to the desired in game resolution in Windows (1080) it still shows without black bars and the 3 sections are greyed out.
I've done some process mon hunting around and discovered this section
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Configuration\DEL4065PH5NY13N274L_0C_07DB_1E^25AE45A8C91AB212A6A8734E4B8D52C3\00\00
(obviously "DEL4065PH5NY13N274L_0C_07DB_1E^25AE45A8C91AB212A6A8734E4B8D52C3" is unique(
There's a DWORD in there which is set to "4" for scaling - which is the one I want - but I believe scaling just turns itself off when not in low resolutions :/
Infact the only way to turn scaling to mainain aspect ratio is to drop to 1280x960 but then it forgets when I go back
(Registry key stays correct at 4 - it's no longer changable :/ however it's 4 - doesn't work though)
Is there a solution to this? It's bloody annoying and frankly, poor design. I want to ALWAYS remember my maintain aspect ratio settings, or configure per resolution. I don't think this has good enoguh controls for me to configure it properly.
I've put enough keywords in this that google might find it, I was tempted to post to AMD / ATI forums but I just can't be bothered, I'm not holding my breath. Worth a shot here though, appreciate your time guys
- thanks
- thanks
