ATI Rage II PC2TV problem! :(
WarDemon666
2,224
I got the card from a friend, he lent it to me, i need it to tape something that is on tape already and edit it for a project. Now for some odd reason i cant get it installed! :( the "video capture" driver does not install properly, and i cannot capture any video. Anyways i have no time right now, but if anyone has any suggestions on what the problem may be, please tell me! :)
BTW: i tried getting updated drivers, still no luck! :(
BeauJangles
13,941
NEed more info... is the card PCI or AGP? What OS are you running? What drivers are you trying to install? What was your previous video card? did you remove those drivesr properly? etc...
WarDemon666
2,224
Well, its like double lol, its 2 cards, ones pci ones isa, umm im running ME, uhhh, im trying to install the video capture drivers, i had a voodoo 2000 pci b4, im putting it back later after i get that movie on my pc....Yes i uninstalled all the drivers, i tried erasing all display drivers and everytihng and reinstalling it like 2-3 times, still no luck! :(
thanks in advance!
Erioll
19
I had the same card (PCI) and the old ISA TV-tuner as well, so I assume that's the components you have as well. I would ask what OS you are using? I have successfully installed that card with its drivers under windows 98SE, but I have no idea about any more recent OS. And I HAVE gotten TV out to work as well.
My suggestions on what to try:
-re-install the drivers for the video card (you don't need to remove them first) and then update your directX. I know this sounds somewhat ludicrous, but slight "tweaks" to my directx config sometimes made all the difference in my being able to run the software correctly.
-remove, then re-install the ATI capture software, and again, update directX. It seems to be REALLY picky about this, so it's always a good idea
-absolute last resort, try booting into "safe mode" and removing ALL drivers for both the main Rage II+ card and the capture board, and then re-boot, and install all from "hopefully" clean. And then again, re-install directx. Beginning to see a trend here?
My install eventually worked, both under Win95OSR2 and Win98SE, but sometimes it would work for no apparent reason, and fail for no apparent reason. You just have to "nurture" it a bit. Praying seemed to help as well. :)
I hope you get it working
Erioll
PS You DID remember to hook up the proprietary ribbon cable between the ISA tuner and the PCI card right? That is essential for them to work together. If that's not on, it won't work no matter what. If your cards don't have a cable, then disregard my advice. I probably have different hardware. But if they have the PINS for a cable, and your friend forgot to give it to you, get that first.
WarDemon666
2,224
Alright thanks, ill keep trying. If anyone else can give me some tips of any sort, please tell me!
oh yeah my friend told me about a jumper that i should try changing around, after i did that, still no luck :(
and one more thing, After i installed the drivers, icq would not load! i reinstalled icq, worked fine, installed the drivers for video card again, icq still didnt load! pretty freeky eh?
anyways,
thanks in advance
P.S. the ribbon is already installed :)
Erioll
19
I wish you luck man.
The jumper thingy I have never heard about. Everything "just worked" on the hardware side of it.
As for the ICQ thing, I have no idea. Of all the somewhat unusual problems I used to have with that board (graduated to the PCI TV tuner of theirs with my new system 2 years ago), ICQ always worked fine. I can't help you there.
I hope you DO get it working though.
Erioll
WarDemon666
2,224
OK! i found out i have the Bt819 chip and not the Bt829 chip, but i CANNOT find the drivers! :( can someone gimme a link to the drivers please? :)
WarDemon666
2,224
I GOT IT!
or close! i can see the screen now, its just the program does an error when i try to capture :(
and virtual dub doesnt capture at all, any sugesstions?
thanks in advance!
wardemon
