ATI Radeon X1050 - Replaceable Fan?
tomhanser
I have an ATI Radeon x1050 PCI-E card in an older Alienware multimedia machine. The fan makes a lot of noise when the box is booted up, for about 2-3 minutes. I'm sure the fan is going but is this a replaceable fan?
It's had to remove this card due to the way this box is arranged and put together - it's not your typical tower with one screw holding in the card. Very involved. The card is oriented fan-side DOWN, so it's not easy to access it.
If I can't replace the fan I guess I'll have to expect to replace the entire card with...? Nothing too over the top - I don't use this box for gaming but for basic DVR and video playback.
Drivers for both Win XP Media Center and Win 7 would be nice!
Thanks!
Red - HD5450 or HD4350. If you want to go green, get the G210 (GeForce 210). Whatever's cheapest of those 3 will work fine for you. And those are passive - no noise 🙂 All 3 offer pretty much the same things.
I wouldn't touch an X1050 with a 10ft pole these days. Even if you would want to repair it - just get a new office-level card (one of the listed above) and enjoy driver updates, new features and usually hassle-free experience under the newest OS.
Thanks! Those two ATI cards and the one GeForce have monster heat sinks - I'm pretty sure that won't fit in this low-profile case.
So I assume this existing card doesn't have a replaceable fan?
Thanks again!
Thanks again!
If that is massive... 😛
As for the fan, no idea. Since you're really low on space, rigging a non-standard fan is out of the question. If you take the card out, clean it and it won't help, you'd need to find the exact same model (maybe a dead one on eBay?) and try to exchange the fan.
However, you can get the above card for roughly $30. I'd just throw the X1050 away and get a new passive card. Saves you a lot of trouble.
EDIT: Here's another pic (this one has HDMI instead of TV Out):
