Hi guys,
I'm looking to replace the fan on ATI Radeon 9000 Pro. My card looks similar to this:
http://www.newegg.com/app/Show....jpg/14-102-391-05.jpg
... but it doesn't have that bulky TV out component. As you can see the fan is pinned into a heatsink. I have no problems taking out the fan, but the heatsink seems permanently attached.
I've looked at other posts and heard about the Vantec Iceberq, but I'm worried it won't be compatible since the heatsink is in the way.
Is this heatsink able to come off? Is the iceberq quiet? Are there any noise reviews on it? Any alternatives to the iceberq? I'm looking for a noiseless or low noise solution.
I appreciate your help
Thanks,
Kub
Thanks,
Kub
