I am getting lock-ups after 10-20 mins of play in most 3D games, The machine will be running perfectly, no corruption or artifacts then bang it will lock-up. The image will basically just freeze and the machine will not respond to ctrl-alt-delete and has to be hard-reset. The tempreature at the crash is normally quite low (29oc sys / 46oc CPU) and there is absolutly no problems before the lock-up.
I have found that if I change my agp speed from 4x to 2x it seems to stop the lock-ups also if I leave it at 4x and go into the advanced smartgart control panel and turn both AGP read and writes off then the lock-ups don't seem to occur.
I am running the latest 4.6 Catalyst drivers but I have additionally tried previous versions and the latest Omega drivers (I re-formatted after each diffrent set of drivers). There was no benefit from trying the other drivers.
Could this be a compatability problem with the mobo and card?
I have managed to run a Geforce 2 mx200 at 4x agp with no lock-ups and also a Geforce 4 mx440 at 8x agp with no lock-ups using the latest Nvidia drivers. (Again re-fromatted after using nvidia drivers)
Some additional details on the mobo are that its a Jetway N2PAP Ultra based on the nforce2 chipset (without on-board video) and is connected to a 300w psu. It fully supports AGP 8x/4x and seems to be a universal 3.0 AGP interface as it can run the cards at 2x as well.
The latest BIOS is in use and AGP aperture size is set to 128mb, I have set it both lower and higher and this doesn't seem to make a difference.
The video card is an a no-name OEM thingie that is "powered by ATI" It is a non-pro Radeon 9000 128mb ddr. This replaced my Connect3d 9000 card that also had lock-up problems, this though went back to the shop as they thought the lock-ups were due to a faulty card (which it obviously wasn't). Also a new, more powerful PSU was tested by my local shop. I still had the lock-ups even with the new card and PSU.
If anyone has ANY ideas as to why this is giving me so many problems please help as I am at a loss. My only other thought is to maybe use the ATI Smartgart uninstaller. Could smartgart be causing the problems.
Cheers
Jon
Cheers
Jon
