Hi to all.
I have a pc with the following configuration:
Athlon XP 1800+
Gigabyte 7N400 - L1 chipset nForce2 ultra 400 dual channel
HDD maxtor 60 gb 7200 rpm
256 DDR pc 2700, 333 mhz
ATI RADEON 9200 64 MB DDR by PowerColor
Monitor Nokia 447Xpro (see technicall descpription at http://www.monitoroutlet.com/475347.html)
The problem is with my ATI Radeon: I am setting the monitor refresh rate at 100Mhz for a resolution 1024x768 pixels, in the monitor properties it says that the refresh rate is 100, but it stays at 60 Mhz!!! (I've made a self test to the monitor and invariable it refreshes at 60 mhz). All theese problem appears with all Bios setting by default. I've tried to upgrade the video driver.. the same; I've changed the bios settings (AGP transfer rate: 8x, 4x; the frequency 50->100 mhz, AGP voltage) The same problem.
I've changed the Nokia monitor with a older one (Siemens-Nixdorf) and all is OK. I've used the nokia monitor on another pc (intel celeron with an riva tnt 2 at 32 mb and all is ok).
What can I do? Do you ever heard of this kind of conflict ever? Please help ! Thanks in advance for any tip.
Bye!
Aiko
Athlon XP 1800+
Bye!
Aiko
