Ati Radeon 4650 low fps Help please
xxJon
My card used to run crossfire [the game] At around 150fps in a full room with 16 people, now it stuggles with 40fps in a full room. I have reformatted it and still same fps. Tryed alot of different drivers and its the same.
And here are my system specs
Intergrated ati radeon 2100[Disabled]
Ati radeon HD 4650
AMD Phenom 8400 Triple core
3GB ddr2 Ram
Windows 7 ultimate 32 bit
Here are the REQ for the game: http://crossfire.z8games.com/downloads2.aspx
Minimum Requirement
Recommended Requirement
CPU
Pentium 4 - 1.5GHz
Pentium 4 - 2 GHz
MEMORY
512mb
1GB or higher
VIDEO CARD
GeForce 5600
or equivalent class
GeForce 6600
or equivalent class
HARD DISK
1.2GB
SYSTEM
Windows XP, Windows Vista and Windows 7
DIRECT X
9.0 C or later
INTERNET CONNECTION
Cable/DSL or better
cusideabelincoln
3,275
46
Hmm I'd say make sure the CPU is running at it's full speed when you're playing the game and that it's not throttling down to like 800 mhz.
Borealis7
2,901
205
download a benchmark like 3dMark or something and run on your computer to compare it with other scores for the same video card. it could give you an indication if something isn't working as fast as it should.
killster1
Banned
Mar 15, 2007
6,205
475
maybe its your internet? like someone else said check another game or benchmark.. maybe card is overheating? cpu overheating? something is throttling down?
notposting
3,503
40
Well the CPU could be throttling down if it's overheating, or cool n quiet could be kicking in when it shouldn't.
Have you checked the settings in the BIOS to make sure they are all correct? Is the date correct in the BIOS? If the battery died on the board it might have reset to defaults (grasping at straws here).
CPU-Z will show your CPU speed...launch the game and then switch to the desktop and see. GPU-Z will show your graphics speeds and temps, and you can have it record them so you can run the game and then flip to it and see if it was up to speed during the game. Coretemp will get your CPU temp for you so you can verify it isn't overheating.
Do you move the PC a lot? Maybe the heatsink for the cpu got loose and the processor is constantly throttling back?
xxJon
These are my GPU clocks when im running the game in the OP
GPU Core Clock [MHz] , GPU Memory Clock [MHz] , GPU Temperature [°C] , Fan Speed [%] , GPU Load [%] , Fan Speed [RPM] , GPU Temp. #1 [°C] , GPU Temp. #2 [°C] ,
2 47.0 ,
2010-05-29 10:56:57 , 630.0 , 526.5 , 46.0 , 13 , 66 , - , 46.5 , 47.0 ,
2010-05-29 10:56:58 , 630.0 , 526.5 , 47.0 , 14 , 74 , - , 47.0 , 48.5 ,
2010-05-29 10:56:59 , 630.0 , 526.5 , 48.0 , 16 , 82 , - , 47.5 , 48.0 ,
2010-05-29 10:57:00 , 630.0 , 526.5 , 48.0 , 16 , 92 , - , 48.0 , 48.0 ,
2010-05-29 10:57:01 , 630.0 , 526.5 , 48.0 , 16 , 95 , - , 47.5 , 48.5 ,
2010-05-29 10:57:02 , 630.0 , 526.5 , 47.0 , 16 , 97 , - , 47.5 , 48.5 ,
2010-05-29 10:57:03 , 630.0 , 526.5 , 47.0 , 16 , 90 , - , 46.5 , 47.5 ,
2010-05-29 10:57:04 , 630.0 , 526.5 , 46.0 , 13 , 82 , - , 46.0 , 46.5 ,
2010-05-29 10:57:05 , 630.0 , 526.5 , 47.0 , 13 , 66 , - , 46.5 , 46.0 ,
2010-05-29 10:57:06 , 630.0 , 526.5 , 47.0 , 13 , 57 , - , 45.0 , 47.0 ,
2010-05-29 10:57:07 , 630.0 , 526.5 , 46.0 , 13 , 49 , - , 45.5 , 46.5 ,
2010-05-29 10:57:08 , 630.0 , 526.5 , 47.0 , 14 , 56 , - , 46.5 , 47.0 ,
2010-05-29 10:57:09 , 630.0 , 526.5 , 47.0 , 13 , 62 , - , 46.0 , 47.0 ,
2010-05-29 10:57:10 , 630.0 , 526.5 , 47.0 , 14 , 69 , - , 46.5 , 47.0 ,
2010-05-29 10:57:11 , 630.0 , 526.5 , 46.0 , 14 , 68 , - , 46.5 , 48.0 ,
2010-05-29 10:57:12 , 630.0 , 526.5 , 47.0 , 14 , 69 , - , 46.0 , 48.0 ,
2010-05-29 10:57:13 , 630.0 , 526.5 , 46.0 , 13 , 69 , - , 46.5 , 47.0 ,
2010-05-29 10:57:14 , 630.0 , 526.5 , 47.0 , 16 , 68 , - , 47.0 , 48.0 ,
2010-05-29 10:57:15 , 630.0 , 526.5 , 47.0 , 14 , 67 , - , 47.0 , 48.0 ,
2010-05-29 10:57:16 , 630.0 , 526.5 , 47.0 , 14 , 65 , - , 46.0 , 47.0 ,
2010-05-29 10:57:17 , 630.0 , 526.5 , 47.0 , 13 , 63 , - , 46.5 , 47.0 ,
2010-05-29 10:57:18 , 630.0 , 526.5 , 46.0 , 13 , 61 , - , 45.5 , 46.0 ,
2010-05-29 10:57:19 , 630.0 , 526.5 , 46.0 , 13 , 59 , - , 46.5 , 47.0 ,
2010-05-29 10:57:20 , 630.0 , 526.5 , 47.0 , 14 , 60 , - , 47.0 , 47.0 ,
2010-05-29 10:57:21 , 630.0 , 526.5 , 47.0 , 16 , 63 , - , 47.0 , 47.0 ,
2010-05-29 10:57:22 , 630.0 , 526.5 , 46.0 , 13 , 66 , - , 46.0 , 47.0 ,
2010-05-29 10:57:23 , 630.0 , 526.5 , 47.0 , 13 , 63 , - , 47.5 , 46.5 ,
