- Mar 3, 2009
- 933
- 0
- 71
I'm running an XFX 5850, along with a HannsG 28in Monitor. I know how to go into the CCC and and just the scaling to zero to get rid of the black framing when I first boot.
The problem I'm having is that it every time I boot, the black bars are still there. I go into CCC, and the GPU scaling is still set to zero. I have to dial up the counter and push it back to zero to remove the bars. Obviously this isn't a huge performance issue, but more of an annoyance every time I need to boot up. I'm using the 10.8 Catalyst drivers, and have uninstalled reinstalled a couple times, and also using a DVI > HDMI cable. I've tried messing around with profiles, but that didn't seem to change anything after a restart.
When I was running dual 4890s I had to do the GPU scaling, but the settings would be adjusted during the boot. Same with with the gtx470 I was running. This is my first 5000 series of cards.
Anyone else experience something like this? I tried doing a google search, but only came across how to remove the bars, not any problems with the settings not saving/registering.....So I take, this might not be a common problem.
Any help would be most appreciated.
