Ok. So I finally got my new cards in the mail. They both POST, though they are acting very weird. I went into my catalyst control center to make sure they are running fine (everest did not detect their temps) and they were both at 25 C. So I activated manual control and changed the fans to 100% to check if they were working fine (which worked). Then one of the fans just stopped. It shows 0C temp, 000MHz GPU, 000MHz Memory, AND the other card shows 157MHz GPU, 300MHz memory. No matter what I change the setting to it does not affect this
also my previous card was a HD4850x2.
CPU: Phenom II 955BE
PSU: 750W
OS: Server 2008
Update: The second card randomly turns back on then off. Everest shows the memory clock as 300Mhz for both...
PSU: 750W
OS: Server 2008
