- Apr 11, 2006
- 4
- 0
- 0
Hi everyone,
I did a search on this forum and I noticed that a lot of people don't like the CCC since it seems to be really slow. I've seen various things mentioned but none seemed like the case that I'm experiencing. So I just want to know the final verdict for the CCC.
I recently bought a Dell Inspiron 6400 with an ATI X1400 card. It has a Core Duo T2400 (1.83 GHz processors) with 1 GB of RAM. Right when I turned on my computer, I experienced an immense slowdown. After a few days, I discovered that it was the CCC causing the problem. When I start the Control Center, my system slows to a crawl. Mouse tracking takes over 10 seconds per response and I can't do anything. After about 10 minutes, CCC finally loads and everything returns to normal speed.
It would be great if anyone could answer some of my questions since obviously a lot of you have had similar experiences. I'd like to know:
1. Has this slowdown happened to you to this extent?
2. How can I get around this issue or how have you dealt with these problems?
3. What is the CCC acutally doing to cripple my computer? Is it a sign of video card problems or other hardware issues?
4. Is the CCC just for settings, or does having it open actually improve video card performance?
Thank you so much.
EDIT: My video driver version is 6.14.10.6587
Thank you so much.
