ATI cards? using all 3 outputs DVI,Svideo,VGA
sman789
Banned
May 6, 2003
1,038
I'm thinking this won't be a three display setup but would it be like 1 main screen (say a CRT), the extended desktop (DVI LCD) and a TV on the svideo. Would the LCD and TV be the same output? or would the TV not even work?
titanmiller
2,123
Not sure, but I belive any card with the exception of the Matrox Parhelia can only do 2 seperate displays at any one time.
kursplat
1,547
do you just want to see your desktop on a TV or other monitor ? or do you want your desktop to "span" across the monitors , 1/2 on 1 and 1/2 on the other?
you can have your desktop show up on all the different outputs at once but it will be the same. i don't belive you can do this (2nd pic) with thw ATI.
good luck
sman789
Banned
May 6, 2003
1,038
right now i just have a CRT and a TV
when i use the TV as the 2nd it extends the desktop but it doesnt have a taskbar and the wallpaper is a copy of the CRt's. I guess i should have a custom resolution if i want the taskbar accross both.
But what i want is the CRT with a 1024res as a gaming monitor and i'll use a 4inch svideo TV for system monitoring. The LCD will be cloned by the TV but i wont need the lcd on for system monitoring
