ATI All In Wonder Radeon (TV PROBLEM) w Terminal Server HELP
RiceDiGiZ
258
Is there any way to have Terminal Server and Tv together?
"TV player failed to initialize the video" error, Windows 2000
FROM ATI SUPPORT WEBSITE
This issue affects the ATI TV Player from Multimedia Center 7.0 when used under Windows 2000.
The error "TV player failed to initialize the video" can occur if resources required by the ATI TV Player are already in use by another application or are not available on the system.
If Windows 2000 Terminal Services are installed
Windows 2000 Terminal Services must be removed from the system in order to use the ATI TV Player.
By design, Microsoft Terminal Services disables all audio redirection when installed. Any services or devices that redirect audio will fail to load under these conditions.
The ATI WDM audio devices are used by the ATI TV Player to redirect audio. These required devices will fail to load if Terminal Services are installed.
To correct this error condition, uninstall Windows Terminal Services.
If you have any questions about the information above, contact ATI Technical Support and reference INFO-BASE file # 3728
Keywords: ALL PRODUCTS for PC MICROSOFT WINDOWS 2000 TV PLAYER ATI MULTIMEDIA CENTER TERMINAL SERVICES
