ATI AIW X600 Pro problems
smitty2005
38
The newbie first-time build from hell continues...
OK, so I solved my MoBo grounding problems (see earlier thread, "Help! Help! Help!"), got my system to start up with all the right lights lighting and proper sounds, uh, sounding.
When I finally plugged my monitor in, I got a garbled, unreadable screen.
So, I took the X600pro out of the PCI Express slot, yanked an old 3dfx card from an ancient system and plugged it into a PCI slot. Voila, I finally get my first positive experience, the Epox opening screen followed by the setup screen.
So, I know the problem is with the card.
I had the x600pro firmly seated into the PCI-E slot, but I didn't have any power cables connected to it. The Installation and Setup Users Guide didn't mention plugging power into the card so I didn't. However, a comp tech at work told me many of the new cards do require power.
Does the x600 pro require power, and if it does how do I supply it?
Could it be a drivers issue? Is it possible that I could install Windows using my old card then install the drivers for the x600pro afterward?
Is it likely the card is defective?
smitty2005
38
Oh, here's my stem by the way:
AMD Athlon 64 3000+ Venice Processor
EPOX 9NPA+Ultra
Thermaltake SOPRANO VB1000SWS Silver ATX Mid Tower Case
OCZ PowerStream OCZ420ADJ ATX 420W Power Supply
Corsair Value Select (Dual Pack) 184 Pin 512MBx2 DDR PC-3200
Samsung Spinpoint 200GB:
ATI Radeon X600XL PCI-Express AIW Video Card
BenQ DVD Burner
