- May 31, 2001
- 844
- 36
- 101
I currently have an ATI AIW 128 PCI (32 mb) video card in my system (SiS 5591 mother board w/ AMD K6-2 450 processor) along with two Diamond Monster 3D II voodoo2 cards in SLI. Unfortunately, from what I've read, if I upgrade from DirectX7.0a to DirectX8 in Win98SE, I will loose the Voodoo2's in Direct3D games (I'm not sure if they will still work in OpenGL and Glide games, but I suspect they will). I have access to a Voodoo3 3000 AGP card, which I think will work with DirectX8 if I use the drivers available from x3dfx.
What I would like to do is use the AIW 128 PCI in system with the Voodoo3 3000 AGP. That way, I would still have the TV & DVD features of the ATI card, but I could play the games I want to play on the Voodoo3. If I just use the Voodoo3, I'll lose the DVD features from the ATI card, and I'll have to buy a separate DVD decoder card (the Voodoo3 won't play the DVD's on my slow system since it doesn't really have any DVD acceleration).
I've seen a little about the multiple monitor support in Win98SE, but I'm not sure if it is feasable with these two cards (or even if it is the proper feature to use). I don't really need it to display on two monitors at the same time. I would like to be able to set one as the primary display when I want to use it, and hook the monitor to it.
I remember seeing a system from one of the gaming system manufacturers (Alien or Falcon) a couple of years ago that had a Voodoo3 and a TNT2 in the same system. They had a switch box attached to the video out ports of each card. The monitor was then attached to the switch box so that you didn't need to physically move the monitor cable between the two cards.
Any help would be greatly appreciated. I know that it is time to upgrade, but I have to keep peace in the family (my wife doesn't appreciate my computer/gaming habit).
My current system specs. are:
Motherboard: M-Technology R581A (SiS 5591 chipset)
Video: ATI AIW 128 PCI (32 Mb), (2) Diamond Monster 3D II (12 Mb each)
Sound: Creative Labs Soundblaster 16 ISA
Thanks in advance.
Thanks in advance.
