The specs on the ATI Radeon 9800Pro 128MB card say it can output 1920 x 1200 resolution, which I want to do so it will drive my EIZO monitor at its native resolution. But will this make the card run hotter?
In any case, since Ill only be using the cards DVI-D output, there will then be no digital to analog video conversion taking place, correct? If so, would there at least be a little less heat output from the card, since it will have to do that much less work?
