Prizef1ghter
When the PC goes through POST, all the text information is garbled and infused with random characters and video artifacts like brite sprites until windows starts. After windows starts, the screen is 'ghosted' by a bunch of half inch vertical 'hash marks'. There is tearing in 2d desktop when an application is running and in 3d mode there is also bad artifacts and tearing.
It didn't start out this way. When I installed the card and the latest drivers, it worked fine for a couple of days.
I cannot be a driver issue because it happens immediately at POST.
The MOBO is flashed. Giga- Byte GA-8IPE1000 Pro - G
The monitor is not the issue because I swapped in another and it displayed the same problem.
I put in an old video card and the problem did not occur.
The power supply is 330 watts.
Of course I did go through trying to uninstall and reinstall drivers. But when I removed all the ATI stuff with the cleaner tool, I still had the problem with absolutely no drivers present.
Any ideas on what the problem might be?
