ATI 9600 Pro TV problems (No color)
GAMBILL
100
Hello,
I just got my 9600 pro installed, and when I hook up the s-video to the tv it's black & white instead of colored, is the card no good or do I need to change something in my setting's?
Thanks Gambill
Lonyo
21,938
Change settings Ii believe.
Make sure you have the composite/s-video out settings correct, and the right sort of settings for your area (NTSC/PAL settings).
Those are the 2 things I can think of at the moment. Not sure where they might be in the drivers, I have an nVidia card.
Serp86
671
had exactly same problem with 15yr old tv
Try the RCA to S-video converter that should have been supplied with it. Should work
