My systems a bit old but here are the specs.
XP 2000
Asus A7V333
1GB DDR Ram (kingston)
40GB Maxtor Drive
ATI Stealth 9550
Anyway, my old GeForce 4 ti4400 stopped working so I went out and got a new replacement card, the 9550. I only really wanted a cheap replacement, nothing fancy.
I installed it and heres whats happening.
Often when the computer runs for 5 - 10minutes everything locks up and the computer restarts. When I try to enter a game, it will play for about 2 minutes then it will lockup (though the sound will still work). Sometimes the game will crash and I will get an ATI error saying that my Video Driver Stopped working and the system switched to software rendering oppose to hardware.
My card is not clocked, all factory settings with the latest ATI Cat. Drivers.
This is not an overheating issue, ive checked 20x and it is not possible for it to be an overheating issue. I also know this because I semi fixed the problem...
What I did was instead of my CPU to AGP VIA Drivers, in its place, I installed the PCI Standard PCI-to-PCI Bridge driver. Once I did this, I am having no stability issues. This however, is by no means a fix. When I run games the card performs worse then my GF4, for obvious reasons.
I have also tried installing an older version of the Cat Drivers from the manufacturers CD and it was stable for a longer period of time.
I can't find a fix on google anywhere, anyone have any ideas?
Thank you kindly
XP 2000
Asus A7V333
40GB Maxtor Drive
ATI Stealth 9550
Thank you kindly
