Brand new Biostar M7VIT pro with a ATI 9500pro no other issues, W2k - SP3, 512mb 2700 DDR, laters chipset drivers loaded, latest catalyst drivers loaded.
IO range C000-C0FF not available
Drivers will not load because the card cannot find the above resource. No device is listed to be currently using that range so I cannot rely on that to tell me where the potential conflict lies... Has anyone else had a problem similar to this? Disabled everything possible to try and find a conflict, but nothing worked. Useless ATI support just tells me I probably need to get another motherboard because its a MB issue, but I dont buy that, and if it is the case, I would rather get a new VID card, I find it very "uncool" that they could have such a critical incompatability issue and not provide any warnings to shoppers. btw, all parts are brand new.
