ati 9500 or 9700, long read but PLEASE HELP
tyler811
5,385
Hi All,
Ok I have problem, I just built a computer on a Biostar M7VIK Maxtor 60 gig 7200 rpm, 300 watt ps, Sound Blaster Live 5.1 gamer, AM XP 1800, Windows XP Pro and the video card below.New bios, video driver, sound card driver, 4 in 1 hyperion drivers and Direct x 8.1. Here is the story. I put this together and every went together great. I ran Mad Onion ( The lastest one ) and it rebooted the computer. Tried to play BF 1942 and it was horrible. This was 2 weeks ago. I have since uninstalled and reinstalled in this order video driver then sound driver then both then video and tried older sound driver. old video new sound driver, old 4 in 1 driver & new video and sound, new old 4 in 1 & old video and sound. Then .............. well you get the idea I have tried every conceivable option there is. . Then I looked at the driver cd and it says "DRIVER FOR ATI 9700 PRO ONLY" Now I never tried tried to put the cd driver on because I got the lastest ones off ati website.So I uninstalled the drivers I had on the machineand tried to put in the drivers off the cd. I got a "CANNOT INSTALL DRIVERS CANNOT FING INF FILE". So I did the install again off the cd but this time pointed directly to the drivers and got the same message. So I reinstalled the new video drivers from ati website and still had the same thing. Now I am completelt baffled so I did a complete format and reinstall of everything including windows xp pro. Now I can complete MADONION but when playing MAX PAYNE or BF 1942, I get kicked back to my desktop. Sometimes I can for for a few minutes or up to a 2 hours but I always get kicked back to my desktop. I thought i had the wrong drivers so i went back to ATI and did a product check with bios string thru ATI's bios string check. It came back I had a ATI RADEON 9700 and not the ATI RADEON 9500 as listed below from newegg. Then a favorite uncle of mine sent me a test called AIDA 32 and the results are below that. Now when you look at the AIDA 32 results keep in mind that the 9500 has only 2 vertex shaders and 4 pixel pipelines, 128 bit memory. Mine according to the AIDA 32 has 4 vertex shaders, 8 pipelines and 256 bit memory plus the faster clock speed and memory speed but mine only has 64 ddr memory and I cant find a 9700 that comes with 64 ddr only 128 ddr. Right at this very minute I am using 9500 video drivers, the Hyperion 4 in 1 4.45 drivers, and the lastest sound blaster drivers plus all the updrades for XP. I can complete the MADONION with a score 9456 and BF 1942 looks and runs excellent but right before Ithe game loads into whatever server I am on I get 8-10 multi colored blocks at the bottom then it connects no problem. It runs fast but I always get kicked back to my desktop. This is a fast system for me and I love it. But can someone please help me out here PLEASE
this is what I thought I was buying from New Egg. The first is a description from Newegg and below that is the description from the link at Saphire who made the card.
ATI OEM RADEON 9500 64MB DDR 8X AGP BULK
Specifications:
Chipset: ATI RADEON 9500
Memory:64MB 128-bit DDR memory
Supports the new AGP 8X standard (2.0 GB/sec)
Unique VIDEOSHADER? engine uses programmable pixel shaders to accelerate video processing and provide better-looking visuals
ATI's latest FULLSTREAM? technology removes blocky artifacts from streaming Internet video and provides sharper image quality
SMARTSHADER? 2.0 technology allows users to experience complex, movie-quality effects in next-generation 3D games and applications
OEM Box (see pics) "Powered by ATI" Manufactured By Sapphire "Powered by ATI" Manufactured By Sapphire Model#: RADEON 9500 64M (S) -OEM
64MB or 128MB DDR memory accelerates the latest 3D games
128-bit DDR memory interface provides end users with fast graphics performance
4-pixel pipeline architecture cuts rendering time in half when compared to any competing product
Supports the new AGP 8X standard, providing a high-speed link between the graphics board and the rest of the PC (2.0 GB/sec)
Provides full support for Microsoft® DirectX® 9.0 and the latest OpenGL® functionality
SMOOTHVISION? 2.0 technology enhances image quality by removing jagged edges and pinging out fine texture detail, without compromising performance
128-bit floating-point color precision allows for a greater range of colors and brightness
This is what ADIA 32 says I have.
Graphics Processor Properties:
Video Adapter ATI R300
GPU Code Name R300
PCI Device 1002 / 4144
Transistors 110 million
Process Technology 0.15u
Bus Type AGP
Memory Size 64 MB
GPU Clock 277 MHz
RAMDAC Clock 400 MHz
Pixel Pipelines 8
TMU Per Pipeline 1
Vertex Shaders 4 (v2.0)
Pixel Shaders 1 (v2.0)
Pixel Fillrate 2216 MPixel/s
Texel Fillrate 2216 MTexel/s
Memory Bus Properties:
Bus Type DDR
Bus Width 256-bit
Real Clock 270 MHz (DDR)
Effective Clock 540 MHz
Bandwidth 17280 MB/s
kmmatney
4,363
It sounds like you may have been a shipped a card that somebody previously bought, flashed to the R9700 Bios, and then returned. Maybe you can get a hold of the original 9500 Bios and flash it back. That's my guess...
Killrose
6,230
8
You might have someones failed attempt. Especially if you bought a refurb. To Flash, need the atiflash utility and a bios. Go to the rage3d forums and check the sticky there in the overclocking section. It has a link to Warp11's bios's, and the Ati flash utility.
Then again, you could have a defective card.
