- Feb 10, 2001
- 9,837
- 0
- 0
Friend of mine has an ATI AIW 7500 64Mb PAL card from Hercules (E-bay), and XP Pro, having troubles getting it to do anything without hanging. He has the latest ATI drivers (MMC 8.8, Catalyst 3.10, DAO 8.1) but if you start the TV application, the splash screen appears, and the program hangs- ATIMMC.exe taking up 99% CPU time.
The only way to get rid of that windows is to use the remote to kill what it calls the "foreground window" (splash screen) and then use Task Manager to kill off the offending program.
The program works on a clean install if you install in a certain order, but Windows updates some files itself without telling you what. He also has DirectX 9 instead of 9b; apparently there's some bug with the AIW cards and 9b but I don't think that applies here.
Anybody got any ideas on what file is being updated, or what is updating said file(s)?
Cheers!
Cheers!
