- Sep 22, 2008
- 2
- 0
- 0
I am trying to run a dual monitor set-up with the just-purchased HD4850 (Diamond), Vista 64, and latest Drivers.
Monitor 1 (primary): Acer 22in 1680 x 1050 (landscape)
Monitor 2 (Secondary): Dell 20in 1600 x 1200 (portrait)
When I first connected the second monitor (Dell) I went to CCC, enabled the monitor, rotated to 90 degrees, and adjusted the resolution. Everything worked great. Then I re-started windows and my second monitor was disabled. Again, I manually re-enabled and adjusted the settings, but after re-start second monitor would be off. I Re-installed the drivers (8.9) and CCC but still could not get it to keep the settings after re-boot.
After hours of trials and frustrations I figured out that ATI will keep my dual monitor settings ONLY if the resolution on my primary monitor (Acer) is set to 1440 X 900 or below.
But I know that the card is capable of running both monitors at their native resolutions because I can go into CCC and manually stet the proper resolutions - it works...It just doesn't keep those settings after re-start.
Any suggestions?
Any suggestions?
