Athon system locks up
WOU
4
Please Help!
I have a gateway Athon 850 system. This is about an year old system. This thing will always lock up no matter what you do. Whether I surf on my cable modem or be playing a card game. The system will do a total lock up. (Can't move the mouse, can't alt ctrl del, or anything). I've runned out of ideas on what to do. I've checked all the IRQs, Took out the SB live sound card and ran it (It froze as soon as I rebooted). I reformatted and did a clean install of the OS both win98 and ME. Use Nortons util, to try to figure it out, still no good. Took out the Graphics board and switched it with a lower spec one. Did defrag and scandisk. Nothings works.
Here are my spec.
Athon 850 mhz.
Not sure what type of mobo but it has the AMD 756 chipset.
192 mb sdram pc100.
Riva TNT2 32mb graphics card.
Western Dig. 20 gb HD.
SB Live sound card.
200 watt power supply.
Any help would be great!
tbalon
419
Has the system done this since you got it, or has it just started doing this?
here are some possibilities:
1. Overheating - check to be sure that all fans are working corectly. Are you monitoring the temperature of the CPU? This is important, an overheating proccessor will freeze your system. Is the heatsink and fan attached properly to the CPU?
2. Voltages - Is the CPU receiving the propper amount of voltage? If the voltage drops too low it will freeze the system.
There are several shareware programs available that will monitor these items for you. Hope this helps,
Good luck!
