AthlonXP Retail for non-Oc'er - how's the noise?
Jeff H
Guys,
I may be building a budget system for a friend; considering an AthlonXP 1700+ retail cpu. I'm not going to go into overclocking on this system - he'd rather have a stable system that he doesn't have to worry about. How's the hsf on the retail units? Is it quiet, relatively speaking, or would we be better off going w/ an aftermarket cooler w/ a quiet 80mm fan?
Thanks for your input,
Jeff
The stock units are a little noisy. Try it, if it's too loud, get a gc68 from svcompucycle or galaxy monster from nexfan- same thing. I know, seems too cheap to be any good, but they work nicely, and are a real bargain.
Yes, get an aftermarket hsf. SVCompucycle has the SK6 for 10.00 and you can mount an 80mm Panaflo (ultra-low noise) quiet fan on it for 7.00.
Guys,
Jeff
The powersupply, hard drive, and video card fans produce much more noise than the retail XP1900+ in my system.
Guys,
Jeff
Yup, my bro's 1ghz PIII is louder than my Athlon XP1700, but that's mostly because of PS fans and not the cpu fan.
i have an athlon xp 1800 w/ retail hsf. i thought it was quiet when i didnt have any of my case fans going. i thought it was quiet but its not the quietest out there.
An aftermarket heatsink with a quiet 80mm fan is probably a good idea. The retail cooler isn't loud, but it isn't that good either. The Thermaltake Volcano 7 with variable fan speed control is a pretty good option. The Volcano 9 is a good choice too, but it is a bit more expensive.
Thanks for all the replies. It looks like that SK6 @ SVC coupled w/ an 80mm Panaflo might be the ticket.
Depends on what else is making noise in the comp and in the room.
I wouldn't buy another hsf yet. You may not notice the difference in noise level.
Use the retail hsf and if it's too loud, then buy a replacement.
But get some Arctic Silver and use it instead of that thermal pad. Otherwise it will be a pain in the a@$ to replace it later.
My parents' PC has the stock cooler from my newer CPU on theirs, and it's loud as hell. I sleep with my PC on, because the 80mm Panaflo M1a is so quiet, but when I go home, I have to turn their computer off even though the only fans in their system is the one on the CPU and PSU.
Never heard of that one. With such a small heatsink, won't the majority of the air be blowing outside the fin area? Sounds like a really bad idea because of the large dead area in the middle of an 80mm fan. I thought it was especially important to get some pressure into the fins on those. I ran mine for a while with an 80mm, 50 cfm fan, but I rigged up one of the square 80-60 adapters to it. It didn't cool as well as the 60mm Delta, so I got an AX-7 heatsink to use with the 80mm fan. This runs about 1-2*C warmer than the SK-6 with 60mm Delta on an overclocked cpu. I would spend the extra ten dollars on the SK-7 and try a slower standard case fan on it.
It's actually the other way around for me. When I got a retail XP2K+, the HSF was the noisiest thing in my system. Of course, all my case fans are undervolted at 5V and my PS is an enermax whisper. Though I don't think the retail HSF is noisy to the point where it's a problem.
Originally posted by: QuantumSlip
how the heck do you mount it exatly? do the clips still work or do you have to do something more exotic?
For the retail HSF, single notch clip, use a screwdriver to mount.
I thought mine was somewhat loud also. I replaced the 60mm with Aakasa 60 to 80 adaptor and used an 80 mm Vantec Stealth fan. Temps dropped 1-2 c. and somewhat quieter. I also removed the fan from my northbridge because it was also loud. Since my northbridge is so close to the retial hs, I figured that the extra air coming down the outside of the rhs would do an adequate job cooling the nb. I left the thing(heat sink?) that the nb fan screws to on top of the nb. Should I have taken that thingee off?
sbw-
definitely leave the heatsink. Removing the fan is OK, provided that the sink has anything to it at all. Search the forum for <northbridge> for more info....
jhhnn, the ( heatsink) isn't much, it's like just a flat alum. plate w/ mounting tabs for the fan that was on it. My thought that was it would disapate heat better than not using anything at all, considering the cooling that I am getting from the larger cpu fan. Or should I use a better hs? I didn't find anything about my particular setup(stock flat fan mounting plate) when I did a search. Thanks
