Originally posted by: YOyoYOhowsDAjello
Sometimes brand new parts are the worst. You could have gotten a bad part.
Did you run memtest with a different CPU in? (since the computer was on for 5hrs)
If you tested the computer with a different CPU and it was fine, and then changed the CPU and it was crap... it's probably the CPU.
Have you tried lowering the clock of the barton to see if it's stable at lower speeds?
Is this cpu more power hungry than your old one? Maybe your powersupply can't handle your new system?
memtest86 was run with the new CPU hence why I don't think its the CPU. My powersupply is an Antec SmartPower 350W (came with SLK3700-BQE) and the voltage rails seem to be quite stable. My system specs:
AMD AthlonXP 3000+ (Barton core, no OCed)
Abit NF7-S2G (nforce2 400)
2 x 512MB PC2700 Apacer RAM (2.5-3-3-6)
ATI 9600XT 128MB
Creative Audigy DE
40GB Seagate Barracuda IV
80GB Seagate Barracuda IV
LG DVD-ROM
LiteON DVD-RW (SOHW-812S)
1 x PCI LAN card
I think 350W should be able to handle this quite well. It was only upgraded to an XP 3000+ and new mobo, that's it. Everything else is brought over from the last system.
Originally posted by: VirtualLarry
Did you put the heatsink on backwards, so it is not making good contact with the CPU? That was a common oversight when assembling Socket-A systems. Sounds like the CPU might be overheating. Also, does the chipset on the board have decent cooling? The NF2 needed it, especially when running at a 200Mhz FSB, otherwise data-corruption could occur. IOW, load MBM5 or something and check your temps, especially your CPU core temp if that board supports CPU diode temp monitoring.
I've never run this CPU under load yet since it usually reboots before then. The closest I can get it to load was the time I ran memtest86 for 5hrs and then the CPU temp was at 51 C which I think is acceptable for this core. I am pretty sure I installed the heatsink right, but I will check on it and post back if I did put it the wrong way round, but I seriously doubt it.
Any other ideas?
